97 Blazer Clunking in 4wd not in 2wd
Old Sep 3, 2011 | 04:14 PM
KenM's Avatar
KenM is on a distinguished road
Default 97 Blazer Clunking in 4wd not in 2wd
Hello all. I know this has been discussed several times for newer blazers. I have not seen any posts for pre-2000 blazers. I may of just overlooked them though.
My 97 Blazer has the 3 button 4wd switch on the dash and drives great in 2wd. But when I push either the 4hi or 4lo it makes a clunking sound when accelerating and while cornering. Could the 4wd vacuum actuator be a possible cause of this noise by not fully engaging the 4wd? Or is it something else more expensive?
Any help will be greatly appreciated. I have put off fixing this for about 2 years now. thankfully I have not had to use the 4wd in that time. But this year I am going to have to.
Old Sep 3, 2011 | 09:12 PM
warthogdriver's Avatar
have you checked the u joints on the front shaft going to front diff from transfer case?
could be the source..similar to when rear shaft is going out and you get a "clunk" on take off.....my first thought.
Old Sep 4, 2011 | 01:08 PM
KenM's Avatar
Yes I have checked the u joints on the front shaft. They feel like they are good but I guess ya never know. It does not sound like a u joint noise though. this is a very loud clunking sound. It almost sounds like someone taking a sledge hammer and hitting the frame of the truck. It's that loud.
Old Sep 4, 2011 | 01:27 PM
xgiovannix12's Avatar
turn the shaft see if the clunk is coming from the tcase its self
My dads s10 has the same problem i still didn't check it yet but every time i turn the shaft i got a clunk in the t case Im guessing the shaft yoke is bad on my dads pickup 4wd works but i get the clunk noise like you do
Old Sep 7, 2011 | 06:47 PM
KenM's Avatar
I'll have to see if I can get some time this weekend and do some testing to see where it is coming from exactly.
jobiscomplete
Dec 5, 2012 04:48 PM
tonyms1429
Apr 30, 2011 10:24 AM
BluBlazin
Jan 14, 2011 05:58 PM
gp56
Oct 21, 2010 01:06 PM
1blkblazer422
Sep 26, 2009 12:44 PM
