You're making way too much work, and spending money needlessly.
Pull both half shafts out, remove both outer CV joints from the half shafts, install them back into the wheel hub assemblies and torque them down. Done! No need to drain the fluid, there's no driveshaft so the pinion shaft will not turn. The axles are essentially removed so the differential is not turning. |
Originally Posted by Captain Hook
(Post 539212)
The front diff is toast, no need to carry around an extra 75 pounds of useless metal, so it's coming out. It's already mostly out but as I only get one day a week off work and it started downpouring as I was working on the last bolt, it will be finally removed on my next day off (monday). |
I have a 94 bravada with a bad front differential can I do the same thing with it take the drive shaft out and split the cv axles ? it just a beater only drivin 5 miles or so per day
Originally Posted by packrat
(Post 649620)
Post #11 is the cheapest, easiest way to do it. You need to put the outer CV's back in the hubs and torque the axle nuts or the bearing will fall apart. |
But from hell
How did you get the nut off? Mine is very stuck!!
