98 4x4 jimmy pitman arm help
whats the deal with replacing this thing? do i need to completely remove the steering box and replace the arm on the bench? i tried all evening to even just get the jam nut loose and got no where. i unbolted the box to try to get to it and had no luck. the whopping 3/4 of an inch between the crossmember and sector shaft is just great [:@]
RE: 98 4x4 jimmy pitman arm help
tell me about it in the process of doin the same thing to my '94 took some work but got the nut off finally (same thing had to unbolt steering box they don't give you any room at all in there) only now my problem is the stupid pitman arm wont come off (got the puller on but it's bein stubborn) 3 foot long breaker bar on the end of my wrench and all i manage to do is slide myself across the floor so far lol. been soaking it down pretty heavily with pb blaster several times a day since sunday gonna give it another go here in a couple hours hopefully i get lucky. Makes me wanna cry 3 inches of snow here in ohio and im stuck in a little shoebox (98 cavalier) cuz my baby is all torn apart =x
ORIGINAL: ElCaminoManT
You're going to need about 200 ft/lbs of torque to get that nut off, and probably just as much torque to pull the arm off. (assuming you have to correct puller) A good air impact gun is really necessary here. I use a 24v battery powered impact gun for everything, and this was the first nut I couldn't break loose with it. It's a son of a gun for sure.
I believe the torque spec on that nut is 180 lb/ft IIRC.
yep, ended up yankin the box to get at that freakin pitman arm. what a pain in the ****!
Is this the most common reason for play in the steering?
I just noticed mine is a little loose.
ORIGINAL: samuknow
I should have my garage cleaned out by the weekend. If the crappy weather gives me a break. i will check then.
Thanks
Thanks
greatwhite
11-28-2010 11:54 PM
88s10Blazer
12-24-2009 08:43 PM
kornphlake
12-18-2006 02:18 AM
