Abs?
Abs?
i have a 2000 4 door blazer lt with all the goodies. only problem is when i hit the brakes the abs engages almost every time. exspecialy around corners. any ideas?
most likely your abs sensors are either in need of a cleaning at the point where the mount on the hub, or wire itself may be nicked and or shorting out. bad connection also.
this is all assuming you have a 4wd as i do.
i have no exp with 2wd
yes i have 4x4 and ill have to check those. thank you and ill let ya know
Tinted
03-15-2012 02:56 PM
iamchevyman5
02-28-2011 04:35 PM
stormshadow1
04-23-2009 09:46 AM
