ABS-uggg
Old Jan 29, 2011 | 06:01 PM
jjhunny's Avatar
jjhunny is on a distinguished road
Angry ABS-uggg
2000 Blazer, 2DR, 4x4 - So I slow down at a stop light (slight incline) and the ABS kicks in, grinding and thumping against the brake pedal and the vehicle 30 seconds later starts to stop, nearly rear-ending the Lexus in front of us!! This is the first Chevy I have owned and the first ABS system I have ever dealt with. I have heard the for this particular year the whole ABS system has to be replaced!!! I thought there was a blockage in the brake line to the rear brakes (rear not braking) thus the front having to work double time. But I bled the lines and I'm still having this issue. Another thing I have discovered is that the rotors might be warped from this or the warped rotors are causing the ABS to kick in .
Anyone out there experiencing this issue or knows what I am talking about?
I am so over it!!!!
Old Jan 29, 2011 | 06:06 PM
01vortec's Avatar
01vortec is an unknown quantity at this point
Mine does the same thing. my problem is the wheel speed sensor malfunctioning. A temporary fix is to drive in 4wd.
Old Jan 29, 2011 | 06:24 PM
jjhunny's Avatar
Nope, I've had it at the farm in 4HI and 4Lo and it still does it!!! Ugggg
Old Jan 29, 2011 | 06:31 PM
cbr995's Avatar
Sounds like a wheel speed sensor. I believe the sensor is in the hubs on the front. It's built in.
The rear I'm not sure, might be at the end of the transmission.
Old Jan 29, 2011 | 07:41 PM
Frankiesurf's Avatar
Frankiesurf is on a distinguished road
The sensors are located behind the rotor. It is replaceable. I think it is a #15 Torx head bolt.
Old Jan 29, 2011 | 08:05 PM
01vortec's Avatar
Oh mine still does it, but it will atleast stop when its in 4wd.
Old Jan 31, 2011 | 06:07 PM
jjhunny's Avatar
ok what does it look like?
Old Feb 1, 2011 | 08:36 AM
BigBlockBlazer's Avatar
BigBlockBlazer is on a distinguished road
Remove the main ABS fuse until you can get it fixed. You will not have ABS but you will have normal brake function.
Old Feb 16, 2011 | 09:11 PM
jjhunny's Avatar
ok, so i'm guessing the ABS fuse is in the fuse box and not some crazy place that wouldn't make any sense? just to clarify when i remove this fuse i will still have brakes but the ABS assistance will not work? i asked a couple of people about this and they all look at me like i am nutz.
Old Feb 16, 2011 | 10:26 PM
old skool luvr's Avatar
that is correct. under the hood, driver's inner fender between your air box & ABS unit. look under the lid, it'll have a lay-out of what each replay/fuse is for. i think it's one of the 50AMP MAXI fuses. <---oops!
the brakes are hydraulic, not electrical, so it won't affect the normal operation of daily driving. just keep in mind that there won't be any ABS in a panic stop or slippery conditions. 'til you get this fixed of course.
i'd stop talking to, or asking those people, for any advice.
****EDIT**** i should've put in what i thought in the first place. it's the 60AMP fuse in there.
