add a leaf
Old Mar 13, 2009 | 03:20 PM
bj_lucky's Avatar
bj_lucky is on a distinguished road
Default add a leaf
how much height are you getting from doing a add a leaf?
what is the difference between a short and a long?
i did torsion keys and shackles. and because i had to crank the keys to get my tires to work my front sits a bit higher than the back (1/2 inch)
has anyone done add a leaf and shackles? (any pics of how it sits)
Old Mar 13, 2009 | 03:35 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
I'm new to Blazers but isn't the rear an 'axle over' ( SUA) wouldn't adding a leaf lower you down?
Old Mar 13, 2009 | 04:46 PM
bj_lucky's Avatar
a block will lower it, however i believe a add a leaf will get rid of any sag and lift a little
Old Mar 13, 2009 | 08:35 PM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
yah...Search Pro Comp ADD-A-LEAF...there should be a thread that pops up when i added mine. I got about and 1.5" from mine.
Old Mar 14, 2009 | 07:03 AM
purpleblazer95's Avatar
purpleblazer95 is on a distinguished road
adding a leaf will make the whole spring pack stiffer. Spring rates are measured in lbs/in. ie a stiffer spring will compress less for a given weight.
Back to the question. a longer leaf will raise the rear end more but also make the ride stiffer. a shorter leaf will not raise it as much. The grease guy at my work had an extra leaf put in on each side at the local spring shop and it raised the back end higher than could be compensated for in the front. That said he doesn't have torsion bar keys they just cranked up his bars as much as they felt comfortable doing.
hope that helps.
PaulO2288
Apr 21, 2011 12:25 AM
two1nine
Suspension Tech
Nov 27, 2009 07:09 PM
kelraes
Sep 21, 2007 03:10 PM
Mapoftazifosho
Suspension Tech
Sep 11, 2007 04:07 PM
Blindthieves
Lifting Tech
Jul 25, 2007 01:41 AM
