add a leaf kits
Old Apr 11, 2008 | 12:53 PM
Ludachrls83's Avatar
Ludachrls83 is an unknown quantity at this point
Default add a leaf kits
Whats the difference between the long and short add a leaf kits? Whats the best?
Old Apr 11, 2008 | 12:56 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: add a leaf kits
Short adda leafs are cheaper... they go under the leaf pack. They're also a bit stiffer than the long add a leafs.
I'd recommend long add a leafs. They're a bit more work to install, because they go between the top two leafs in the pack, but they distribute the load over a larger area on the spring pack, and aren't as rough on the ride.
Old Apr 11, 2008 | 11:31 PM
rickyp3278's Avatar
rickyp3278 is an unknown quantity at this point
yup jigg's right. I just installed the long add-a-leafs. The shorts are known to give a real bumpy ride. The longs were actually cheaper. only by about 10 bucks though. They gave me just the amount of lift I was looking for. Go for it.
Old Apr 12, 2008 | 03:06 PM
how high should the back of a 2000 2dr blazer be? i think mine has sagged a little. which long add a leaf do you recommend and what is involved in the installation?
Old Apr 13, 2008 | 01:13 PM
prozach1988's Avatar
prozach1988 is an unknown quantity at this point
add a leafs will work even though the spring pack is under the axle
hurleyii
Mar 18, 2014 07:23 AM
PaulO2288
Apr 21, 2011 12:25 AM
two1nine
Suspension Tech
Nov 27, 2009 07:09 PM
peckboy
Lifting Tech
Dec 10, 2008 06:54 PM
lennyblazer
Jul 6, 2007 11:10 PM
