another 4x4 problem
Old 01-03-2009, 11:20 AM
joeyjoey's Avatar
joeyjoey is an unknown quantity at this point
Default another 4x4 problem
first off what a great forum.you guys are very helpfull to the average joe.ok so i have a 94 jimmy 4x4 with push button 4wd.i bought it for the winter and it was working fine.then it would only go from 2wd to 4 low.no 4 high.now it wont even go into 4 low.i read other post and eliminated the vacume actuator under the bat tray.no leaks.it had constant vacumeso i replaced the vac switch on top of the transfer case.still no 4wd.i hit the button and i can hear the electric motor on the transfer case buzzing but still nothing.does this motor.have gears or pins that break or strip?thanks for any help
Old 01-03-2009, 12:38 PM
Default RE: another 4x4 problem
You should start by reading the codes (if any) present in the TCCM. Follow the information in the link below to do so:
NV233 transfer case / encoding motor switch
Trb
02-03-2015 09:41 PM
chrishorton74
06-02-2010 09:03 PM
boater00
01-05-2009 12:32 PM
Da_92James
12-22-2008 04:19 PM
weaves
11-16-2008 08:52 PM
Quick Reply: another 4x4 problem
