Axel Swaps or hubs
Old Nov 11, 2010 | 07:25 PM
jiggs240's Avatar
jiggs240 is on a distinguished road
Default Axel Swaps or hubs
i was just thinking about how the s10 platform kinda got the shaft when it comes to rims. i mean the luv and the colorado both had/have 6 lug rims. how did we only get 5. anyways... i was wondering if it would be possible to put colorado axel shafts and hubs into a blazer. or is there an easier way to make the blazers 6 lug. i've never done anything to any of my vehicles before and was just wondering if this was possible. thanks in advance
Old Nov 11, 2010 | 09:11 PM
NVANZEE's Avatar
not sure about something else fitting but i know the colorados wont work. They have a very weird setup that i have never seen on any other vehicle.
Old Nov 11, 2010 | 09:29 PM
mdehoogh's Avatar
They make adapters that can convert to a 6 lug wheel pattern. However, with the hubs so far out on our trucks, adding an adapter like that would make it a PITA to find wheels that fit right
http://adaptitusa.com/5-lugto6-lugadapters.aspx
Old Nov 11, 2010 | 10:04 PM
Logan's Avatar
Logan is on a distinguished road
Do a wagoneer axle swap...hehehe...bam, six bolt manual locking hubs thhen,,,
Old Nov 11, 2010 | 10:53 PM
69chevelle's Avatar
69chevelle is on a distinguished road
if it makes you feal any better, i got a Colorado and a Blazer... sure the Colroado has a more common bolt pattern... BUT backspacing is STUPID, full size rims will NOT fit as the hub bore on a colorado is much bigger then a 1500 and toyota, and it uses a POSITIVE 33mm offset... our Z71 already has the tires at the very edge of the fenders with 31's(stock) with the oem rims.... 32x11.5 they stuck out a hair and rubbed the frame at full lock.. that's with the z71 flairs
you must never have seen an h3 then :P
Old Nov 12, 2010 | 06:37 AM
jiggs240's Avatar
Thanks for the info guys. I have some old rims from my dads luv that I would like to put on the blazer but unless I go sfa I guess it's not happening. I'm slowly working on the blazer and thought it would be sweet tothrow those on but I'll probably just go with some soft 8's.
88s10Blazer
Feb 4, 2010 04:19 PM
BlazeringSaddles
Jan 1, 2010 12:34 AM
jester78861
Jun 6, 2007 11:59 AM
Jman
Dec 3, 2006 10:59 PM
Mark
May 16, 2005 03:10 PM
