axle??
Old Aug 20, 2008 | 11:20 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default axle??
I was wondering what the axle dimensions are for a 97 2wd blazer. Im looking for backing plate to backing plate width.
Old Aug 20, 2008 | 11:59 PM
WolfPack's Avatar
Default RE: axle??
I got all excited thinking you were going to SFA your 4x4.....then I realized youre asking about the 2wd... boo... [&o]
Old Aug 21, 2008 | 06:58 AM
Default RE: axle??
2wd rears are 48" back-plate to back-plate. 4wd rears are 4" wider than 2wd for a 52" width b-p to b-p. The ZR2 rears are 3.9" wider than regular 4x4 rears, with a 55.9" b-p to b-p.
Here is a quote worth mentioning from hotrodders.com:
I have never figured why so many people go by the backing plate to backing plate. What I really want to know is where the wheels are going to sit. I always go by WMS-WMS (wheel mating surface).
2wd S10 rear end:
54-3/8" WMS-WMS
38-1/2" center pin to center pin.
Pinion offset 1" to drivers side (this was on my 8.5" axle and might be different on a 7.63" axle)
4wd S10 rear end:
From what I understand is 4" wider then 2wd so about 58-3/8" WMS-WMS
Spring spacing same as 2wd and I'm guessing the pinion offset is the same
Ford Explorer 8.8"
59-3/4" WMS-WMS
39-1/4" center pin to center pin (I have heard of people cramming these into S10's without moving the perches)
Pinion offset 2-3/16" to passenger side
There is a short side and long side axle shaft. You can narrow just one side and use 2 short side axle shafts. I don't recall how much this will narrow the axle but I think it will also put the pinion more in the center.
Old Aug 21, 2008 | 07:34 AM
blazin97's Avatar
Default RE: axle??
dang I guess i cantuse the irs outta an 06 GTO, Its 10 inches wider
Old Aug 21, 2008 | 07:40 AM
Default RE: axle??
Yeah, probably wouldn't work out so well.
Old Aug 21, 2008 | 03:45 PM
blazin97's Avatar
Default RE: axle??
yah the gto's is like 58 inches, I didnt think they were 10 inches wider than the blazer.
chowell
Mar 6, 2021 09:47 PM
thrandall
May 3, 2013 04:54 PM
blajeans
Jan 9, 2013 12:58 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
