-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Axle question... (https://blazerforum.com/forum/steering-suspension-drivetrain-36/axle-question-86790/)
Kpearson Aug 8, 2014 11:05 AM
Axle question...
Morning all,
I was just having a quick question as to some axles. I know that the axles from a Jeep wagoneer are the one of choice or popularity, but I was wondering about a set of full size TJ axles. I had talked to a guy near where I live about purchasing them, but I am unsure if they would even really work out. I can buy the full set front and back since they will be upgrading to a stronger axle. So any answer would be great. And if they wouldnt work then no biggie.
AJBert Aug 11, 2014 12:56 AM
Stock TJ axles up front are D30's and are weak. If you are planning on doing a SAS look for a D44 instead.
Jamaroon Aug 11, 2014 01:12 PM
Depends on what your plans are for the truck. But yes, you can use them for a SAS, they just won't be a strength upgrade over what you have now.
Kpearson Aug 14, 2014 01:13 AM
I had decided to move away from those axles. I had figured that I would be able to find better for near the same price. Thanks for the help though guys.
cleburne red Aug 16, 2014 12:41 PM
Good call. If you plan on going through all the work of a SAS, there isn't much point, in my opinion, of going with a D30 in the front. Lifting it will be easier, but like was said above, there really isn't much strength improvement. Do it right the first time, with at least a D44.
abig84 Aug 22, 2014 12:25 PM
im running 10bolts front and back, which are basically just dana44s and been beating the crap out of these axles under my s10 with 33 inch boggers going on like 7 years now and no problems with these axles at all
