Bad rear diff. clunking
Old Feb 24, 2010 | 10:00 PM
mxboy96's Avatar
mxboy96 is on a distinguished road
Default Bad rear diff. clunking
It's a 97 4dr. blaze,4x4, 4.3 like all of um. My rear diff and axel makes a very loud distinct 'clunk' when put in gear, and just today started making that same noise when hitting any bump even as small as a penny almost. I can push the rear end side to side and it sounds as if the rim isn't tightened, but it is. And it does it on both sides. I'm thinking the axel/diff is diffenently loose and some parts will need replacing...What exactly would it be though? Please help! It's driving me nuts! lol. Thanks!
Old Feb 25, 2010 | 09:56 AM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
Did you check the u-joint first to see if it has any play in it? A lot of times the clunk you hear when it is put in gear is the u-joint.
Old Feb 25, 2010 | 10:23 AM
cbr995's Avatar
I second that. A freind of mine had this issue, and it was the u-joints. So he replaced those, now no-mo' clunking.
Old Feb 25, 2010 | 04:57 PM
jsmz's Avatar
Banned for childishly attempting to delete all his posts
jsmz is an unknown quantity at this point
i challenge that. I say wear in the rear end bearings, all of them. But its worth it just to check the u joint first instead of assuming a pinion bearing right away.
My rear end has the same symptoms to a T. No leaks so I put synthetic gear oil in it and am going to ride it out until i upgrade to a disc brakes rear end. You should be fine for a while, but bearings are dirt cheap.
worn shaft bearings causing too much side to side play until the axle c-clip catches & worn pinion bearing causing too much play in the pinion & ring gears, clunk.
Old Feb 26, 2010 | 07:28 AM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
how do you check the u joints? i got this same roblem going on. i put in a whole new used rear diff. less than a year ago and a new tranny about a year ago so im thinking its a u joint problem. I just dont know how to check to see if there going bad
Old Feb 28, 2010 | 05:22 PM
jsmz's Avatar
with truck off put the emergency break on, and the transmission in neutral. crawl underneath and grab the drive shaft. twist it back and forth and see if there is any play in the u joint. it should be tight, no play.
Old Mar 1, 2010 | 06:39 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
That works real good but most of the time you usually don't even have to twist much. You can see if it's shot when it makes a bunch of noise. If it's real bad they really go downhill pretty quick.
DaveRush
Nov 5, 2011 06:30 AM
sob8080
Mar 9, 2011 05:52 PM
BlazerGuy2001
Jan 9, 2010 04:24 PM
Kaffeene
Mar 15, 2008 07:38 PM
tankie88
18
Jan 27, 2006 05:33 PM
