Ball joint grease fittings
Old Sep 4, 2020 | 04:15 AM
No false Bravada's Avatar
No false Bravada is on a distinguished road
Default Ball joint grease fittings
Getting a lot of creaking from my ball joints and I've tried to grease them, but the fittings are rusted. What type of fittings do these take? Like, size and thread pitch
2000 Bravada
Old Sep 4, 2020 | 09:22 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
That could well depend on what mfg the ***** joints are. Take them out and take them to the store with you. Did you try pushing the ball in with a dental or ice pick?
Old Sep 4, 2020 | 11:37 AM
Yes, I tried pushing the little ball in but it won't go. I'll just do that, take the old ones to the store to match.
I wish I had the time and the space to just replace the ball joints
Old Sep 4, 2020 | 01:11 PM
Billy1820's Avatar
If they’re rusted that bad, it’s pretty safe to assume you’ve never greased them. If that’s the case, you’d probably be much better off having a shop change out your ball joints before you end up on the frame with a tire up into the wheel well
Old Sep 4, 2020 | 05:48 PM
daveca's Avatar
Theyre toast. They will have metal fragments inside them.
Old Sep 4, 2020 | 07:25 PM
For what it's worth, I've taken closed stems, and left them soaking in a small pool of wd40(or such), for a couple of days(swishing them around from time to time), and freed them to be able to reuse.
not all of them worked , maybe 3-4 out 5 times success rate.
Old Sep 4, 2020 | 07:47 PM
Not a bad idea at all and vinegar is a great rust remover as well. An overnight soak is all it takes but rinse it off or the rust will return.
porkfriedrice
Jun 11, 2019 06:42 AM
Davecubs14
Jun 4, 2016 10:09 AM
reeladdiction
Oct 24, 2011 06:35 PM
rockrodent
Aug 4, 2010 08:16 PM
truck608
Nov 24, 2006 06:09 PM
