Blazer transfer case trouble occasional
Old Mar 17, 2009 | 08:47 PM
thenours's Avatar
thenours is on a distinguished road
Default Blazer transfer case trouble occasional
Hello , I bought a blazer 2000 4dr , 2 week ago , I have no problem at all to engage the 4Lo and 4Hi , but when i try to disengage the 4x4 , to go into 2Hi , its can take several tries , i heard "click - click" from the TCCM , but its stay on the 4 HI , i have to push the 2 Hi buttom about 10 times , and finally it work
When the motor is cold , it seem be easier , I soon i start the engine , if i push the 2 HI within 1 minute , it work after 2-3 tries , if i'm already running since several minutes.. or even hours.. its can take up to 30 times before disengage the 4x4 , any speed , even on Park , neutral or at 60mph , its the same thing
I heard , under battery there is something.. can be removed and oiled... when the 4x4 cant be disengage at all , its only disengage half and kick back on 4x4 , I have no idea what is.. and if this could fix this issue
I went to shop for change engine oil , there checked everything , there said my differential was missing alot of oil and there filled it up , I dont know if is related to transfer case issue or not
Its not a big problem for now.. Since i still can use both , 4HI and 2Hi
but i was wondering what could cause this problem , its working after several tries... if was not working at all is could be another story but since it occasionally could be a specify part to remplace?
I have another blazer since 6 years , 1999 2dr , and its working awesome , so i was wondering if i could switch the TCCM ? I dont have much experiment about truck , I have no idea where is located the transfer case motor or vaccum line or anything , I have found the TCCM under the kick panel , plug seem all clean
Thank you for any reply
Old Mar 17, 2009 | 09:00 PM
You could try lubricating the front axle actuator cable.
You could also run the codes from the PCM by following the information found in the thread entitled OBD2 Non-Automatic Transfer Case Diagnostics in the Tech Article (DIY) section. See if that turns up any direction for diagnosis.
Flyfishen
Jun 18, 2019 11:22 AM
jmonty0523
Feb 26, 2013 09:59 AM
dudevoit
Mar 8, 2011 06:14 PM
nathanfoudray
Jun 23, 2010 12:41 AM
Don Green
17
Apr 16, 2010 07:51 PM
