body lift ?
Old Dec 15, 2011 | 06:46 AM
JRS ZR2's Avatar
JRS ZR2 is on a distinguished road
Default body lift ?
i have a 99 zr2 blazer and want to do a 2 or 3 inch body lift. i would be doing it myself. my questions are what lines, linkages would i need to be longer to do the body lift. thank you
Old Dec 15, 2011 | 08:18 AM
warthogdriver's Avatar
If you stick with a 2 inch lift not much will have to be extended....find the performance acc. Pdf file online and download it...it will show hou all you need to do. I did mine my self to...its not that bad really
Old Dec 15, 2011 | 09:17 AM
JRS ZR2's Avatar
Ok thank you, how long did it take you to do?
Old Dec 15, 2011 | 01:35 PM
AJBert's Avatar
Eat a hearty breakfast, pack a lunch and plan on a late dinner if you are doing it by yourself. Air tools will speed up the process considerably. Pre-planning will also help you with the time frame. Go over each step BEFORE you start.
Old Dec 15, 2011 | 01:39 PM
Yup..it took me a full day 7 am till way past night fall. But i took my time...watch the frame bolts...that will be the real time killer. Soak them for a couple days ahead of time with pb nut blaster or such
Old Dec 15, 2011 | 06:38 PM
Rottidog's Avatar
Also for a 2nd gen blazer you can only get a 2" B/L unless you don't care where the bumpers sit. Mine has a 3" that was installed before I got it & the bumpers remain at stock height because they don'y make bumper brackets for a 3" lift kit on a 2nd gen blazer. Our rear class III hitch is incorporated with the rear bumper mounting brackets. If you change that they say you can't use it to tow anymore.
Old Dec 18, 2011 | 05:54 PM
JRS ZR2's Avatar
Ok thank you for all of the helpful input.
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
