Body lift questions
I want to do a super mild 2 inch lift, what all needs to be done to accommodate this? My truck has full length factory running boards, stock everything pretty much, would i have to extend any harnesses, Radiator hoses, Transmission/Engine Oil Cooler lines, etc?
I did the performance accessories BL on my 05 2dr a bit ago and it has been going well since I installed it. I needed to extend the fuel filler neck, oddly enough the tubing supplied in the kit was far too big so I needed to source the correct size for that. I also had to extend some ground cables but the kit came with the brackets for that. In addition, it comes with drop brackets to drop the oil filter housing. It also comes with the stuff to lift the front and rear bumpers so they don't look funny. It should be pretty straightforward if you get the performance accessories kit, it comes with all the brackets etc that you will need. I would recommend you get new body mounts at the same time too.
I've installed both the PA kit as well as the Zone Offroad kit, and both came with all the parts necessary to do the lift. All you'll need is some normal tools and a jack. One thing I ran into with the kits is that the ground strap extenders is that they come painted. To ensure that I get a solid ground I either stripped the paint off before bolting them on and then repainting, or just replacing the ground wire with a proper length.
I bought the pucks from Zone Offroad and sourced the bolts locally. I was building my own bumpers, so I didn't need bumper brackets. Basically, I just jacked it up slowly and watched for binding, then extended/relocated whatever was hanging up. I've never been a fan of any radiator shroud "solutions" I've seen, so I went with Intrepid electric fans. I don't remember my filler hose having to be extended, but it's been a while since I did it.
(Post 738415)
Originally Posted by Mods
(Post 738422)
What ground straps specifically need lengthening, since we both have 4 doors - did you have to extend the fuel filler hoses at the tank and unbolt the metal hoses? any weird steering shaft issues, and how was the lineup with the lower valence for the towhooks?
