Brake problems
My pedal is going all the way to the floor where then i will get a little bit of braking. I dont think its a leak in the lines because its not building up any pressure even when pumped and i dont see much loss of fluid. Im assuming its not the booster as wouldnt that give a hard pedal but not much brake. Could it be the abs?
Oh thought you said you don't see much loss of fluid. The seals could be gone inside the master cylinder causing fluid to pass by not creating enough pressure.
try this first, primary piston is closet to the booster.
5. If the brake pedal apply did not feel spongy, but the brake pedal travel was excessive, perform the following steps:
5.1Loosen the master cylinder-to-brake power booster mounting nuts.
5.2Carefully pull the master cylinder away from the brake power booster just enough to inspect the mounting surface of the master cylinder.
5.3Inspect the master cylinder mounting surface at the primary piston (2) for brake fluid leaks.
