Brake problems
Old Dec 23, 2012 | 02:36 PM
BEASTLYWARRIOR228's Avatar
BEASTLYWARRIOR228 is on a distinguished road
Default Brake problems
My pedal is going all the way to the floor where then i will get a little bit of braking. I dont think its a leak in the lines because its not building up any pressure even when pumped and i dont see much loss of fluid. Im assuming its not the booster as wouldnt that give a hard pedal but not much brake. Could it be the abs?
Old Dec 23, 2012 | 02:38 PM
chris015's Avatar
Sounds like the ol culprit of a bad master cylinder.
Old Dec 23, 2012 | 03:07 PM
Ok also the red brake light is on on the dash
Old Dec 23, 2012 | 08:06 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
You sure you don't have a leak? You wouldn't get any pressure even pumping up the pedal if there is a leak in the line and the light comes on when the fluid gets low.
Old Dec 23, 2012 | 11:49 PM
like i said though it's still full on fluid
Old Dec 24, 2012 | 12:39 AM
J_E's Avatar
J_E
J_E is on a distinguished road
Have you tried bleeding your brakes?
Old Dec 24, 2012 | 08:20 AM
Oh thought you said you don't see much loss of fluid. The seals could be gone inside the master cylinder causing fluid to pass by not creating enough pressure.
try this first, primary piston is closet to the booster.
5. If the brake pedal apply did not feel spongy, but the brake pedal travel was excessive, perform the following steps:
5.1Loosen the master cylinder-to-brake power booster mounting nuts.
5.2Carefully pull the master cylinder away from the brake power booster just enough to inspect the mounting surface of the master cylinder.
5.3Inspect the master cylinder mounting surface at the primary piston (2) for brake fluid leaks.
Old Dec 24, 2012 | 10:41 AM
coolasice's Avatar
coolasice will become famous soon enough
is your fluid full in both the front and rear of the resevoir? when that happened to mine the rear caliper seals blew and drained the rear side of the resevoir to empty.
Old Dec 24, 2012 | 02:33 PM
The fluid is full in the master cylinder and there is no front or rear also how would you get air in the lines suddenly
Old Dec 24, 2012 | 04:44 PM
coolasice's Avatar
vehicle year/make/model?
