Bravada driveline vibration 40-60mph and 70+
Ok, I will try my best to explain my issue and what I have done to resolve it, this may get long (I will put a TLDR below)
I have a 98 Olds Bravada that I have owned for 3ish years. Ever since I have had it, it has had a vibration at highway speeds. Nothing I have done has changed the vibrations, for better or worse. I will list all of my repairs below, not all are directly related to fixing the vibration.
Tires re balanced
Transfer case fluid change - put the correct GM fluid in it, not sure how long it had the incorrect stuff
Lower ball joints - passenger and driver
Swapped wheels and tires with friend (did not change)
New brakes all 4 corners - rotors and pads
New U joints (slightly bent front ears so front u joint was tight - this has since been replaced as you will see below)
New tires
New drivers upper control arm - bushings gone
Front drive shaft removal (no change)
Passenger side wheel bearing
Replaced drive shaft with one from junk yard - installed new u joints
I tried to list these in the order they were done to the best of my memory. The most recent was the driveshaft. As seen above, I slightly tweaked the original one and that prematurely killed the front u joint. This was replaced this morning with brand new u joints and still no change.
Now to describe the vibration - its the entire vehicle, but not violent. Just enough to vibrate the mirrors and rattle something in the dash
. This does not matter how fast the engine is spinning. I have tried manually changing gears while this is happening and nothing changes. I also put the truck in N and turned the engine off, no change. I had a buddy ride with me, he sat in the front seat and moved to the back and said he noticed it more in the front of the vehicle than the back.
I am running out of ideas. The ONLY thing that is even on my radar is the transfer case. Now the reason I say this, is my in-laws have a same year Bravada which I compared to mine. I know the transfer case should have some rotational "slop" however mine has 2 times the slop their's has. This is the front shaft I am talking about. Hopefully that makes sense. I cannot really measure this, but with them side by side, it is noticeable. There is not any difference in up/down movement between the 2.
I am about to the point to take it to a shop, however I have a feeling they will just throw parts at it, which I can do for cheaper!
TLDR - Bravada vibration ever since I have owned the vehicle, threw all kinds of parts at it, and no change... possible transfer case?
Thanks Guys.
Tires re balanced
New tires
. This does not matter how fast the engine is spinning. I have tried manually changing gears while this is happening and nothing changes. I also put the truck in N and turned the engine off, no change. I had a buddy ride with me, he sat in the front seat and moved to the back and said he noticed it more in the front of the vehicle than the back.I am running out of ideas. The ONLY thing that is even on my radar is the transfer case. Now the reason I say this, is my in-laws have a same year Bravada which I compared to mine. I know the transfer case should have some rotational "slop" however mine has 2 times the slop their's has. This is the front shaft I am talking about. Hopefully that makes sense. I cannot really measure this, but with them side by side, it is noticeable. There is not any difference in up/down movement between the 2.
Thanks Guys.
I suppose its possible yes. Get a junkyard one instead of taking it to a shop. Shouldnt take too long to swap them out and see what happens. Better than paying a shop to do it for you for sure
i have a '98 bravada, and have had problems with vibrations since iv'e owned it. the transfer case knocks like a piston rod, but it hasn't broke yet, although the 4-wd shift motor swelled out like frozen pop can and no more 4-wd now. i have to say it worked like a charm up until that point. another thing is i understand the '98 is a one year only deal, so finding a transfer case is not easy. im going to the regular blazer, at least they are plentiful. the only difference in the bravada and blazer is cosmetic anyway.
vegasmason
Apr 27, 2008 04:24 PM
AlaskanGrizz
Mar 31, 2008 06:27 AM
