Can the center nut to remove the hub bearing be removed without impact gun?
Old Sep 3, 2010 | 09:02 PM
blacer2000's Avatar
blacer2000 is on a distinguished road
Default Can the center nut to remove the hub bearing be removed without impact gun?
Just like the question says, can I do this with maybe a torch and a big rachet?
And just to make sure it is a 36 mm socket right? Thanks.
Old Sep 3, 2010 | 09:07 PM
I wouldn't use a torch, but a breaker bar and cheater pipe will make it easier. And yes, it should be 36mm.
Old Sep 4, 2010 | 12:04 AM
Leearchibald's Avatar
Leearchibald is on a distinguished road
never use a impact on hub assembly wheel bearings it is a no no and never use a torch
Old Sep 4, 2010 | 01:54 AM
blacer2000's Avatar
ok cool guys, one more thing, anybody know the torque measurements?
Old Sep 4, 2010 | 07:45 AM
What are you driving? The torque value changed over the years.
I have ALWAYS used an impact to remove the axle nut and have never had a return. I do not use it to set the torque, just to remove and then snug it back up and see no reason not to. Work smarter, not harder. Always use a torque wrench to set the axle nut torque.
Old Sep 4, 2010 | 09:29 AM
i know that 98 and up 180 ftlbs and i think 97 to 94 is 160 ft lbs
Old Sep 4, 2010 | 12:16 PM
98+ is 103ftbls on the axle nut, 77ftlbs on the three bolts that hold the hub to the knuckle.
Old Sep 4, 2010 | 08:24 PM
blacer2000's Avatar
Thanks my blazer is a 2000 and today I replaced on it the hub bearing and the cv axle thats why I wanted to know the torques.
Old Sep 4, 2010 | 09:36 PM
When i bought a hub assembly for my 98 it said right in the box do not use impact and torque to 180 ft lbs plus i have a book that has all torque properties for all vehicles wheel bearings from 1965 to 2005.
Old Sep 5, 2010 | 09:01 AM
My value came straight from the FSM (factory service manual) for a 2000 and confirmed in the 98 FSM thru 2005 FSM. 103ftlbs. Maybe your particular brand of bearing required higher torque, but I doubt it. I would rather believe GM. And I could see how tightening completely down with an impact may over torque the connection, but if you know what you are doing, there will be no ill effects from using an impact gun.
importsky22
Aug 27, 2012 07:14 AM
ZR2Winnebago
Aug 14, 2012 08:42 PM
mkm1387
Mar 19, 2012 08:45 AM
nflea7
Aug 25, 2007 09:15 PM
