can i install zr2 control arms on a regular 4x4?
i know there longer control arms than my stock ones, and because so when lifted creates less stress on the ball joints and so on correct? if it is possible the front will be wider than the rear, im not a big fan of spacers but if thats me only choice than so be it
*COMBINING CONSECUTIVE POSTS* also is the upper a-arm different than my stock 1? when i look at the parts they only have upper control arms then high rise wide lower and regular lower a-arm |
RE: can i install zr2 control arms on a regular 4x4?
lift creates MORE stress on the ball joints...and i doubt that you could put them amr son a regular blazer because the zr-2's have a stock lift on them the front of you blazer would probably sit 2-3 inches higher than the rear...if so then you could buy blocks to put between your axles and springs
"if so then you could buy blocks to put between your axles and springs"
You cannot use blocks on a Blazer to lift the reardue to the fact that they are axle over leaf. If you were to use a block it would lower your rear rather than lift it. |
so can i use zr2 control arms? im not worried about the rear becuz theres other ways to lift it. i plan on lifting my blazer with the least amount of stress on the front end, i want it to be relieable. thats y i was wondering if the zr2 control arms would work becuz there made for the lift
to what cookbrady said...i have a 95 blazer and my leafs are on top of my axle so if i put a 2' block in then it would raise my rear end 2' inches...
As for the OP question, yes you should be able to use ZR2 control arms on a non-zr2. From everything I can find, there is no distinction in parts for ZR2 vs non-Z control arms. I could be wrong, as I am just going off memory and what pulls up online for parts...so you might wanna wait till someone else can confirm.
BUT...ZR2 arms or not...theyre not really going to give you anything the non-z arms would. ZR2s do not simply have a lift kit put in...its an entirely different frame and suspension setup. |
ORIGINAL: RWRIGHT to what cookbrady said...i have a 95 blazer and my leafs are on top of my axle so if i put a 2' block in then it would raise my rear end 2' inches... Edit: From your pic here...Your springs are below your axle. Or..you have so much leaf sag...theyre cupping around the axle... http://img3.imageshack.us/img3/5/19c...638e2dda3g.jpg |
i would think the z arms would be longer. If they are longer and they do fit it would help with angles but you would also need longer axle shafts
thanx nvanzee, thats wut i was thinking. i kno there longer by i think 1.5' per side it should help with angles meaning less stress on ball joints and etc...i think this is 1 of the reasons gm made them longer in the first place. ide just like to know if they'd fit
I know the CV shafts are longer, but I believe the control arms are still the same length. If the control arms were longer, that would be the sole explanation for the wider track of the ZR2 package. Also...if ZR2 control arms are longer, why does no one have a ZR2 Control Arm;)
Im stickin to my original...same control arms...different trucks :D |
i will see if i can find out at work tomorrow
ok thanx
BUMP!!! Any word yet?
