Cant find the issue, 4x4
Ok so after doing some research, I cant find any help. I went out today and took my battery and tray out, hooked the battery up thru the jumper cables and started the blazer back up. I had a friend hit the 4wd and I watched the actuator. The actuator works like normal, but still no 4wd. It pulls the cable and everything. This is my first IFS 4wd. I dont know how it works after the cable. Anyone else have any idea as to what it could be?
Are you getting a service 4x light? Switch on dash flashing?
Did you look at the encodee motor on transfer case to see if that is engaging? It is on driverside of transfer case by front drive shaft...see if that is working. You can do a search to check pics so you know what you are looking at.
1st off what are you driving ? how many buttons do you have in the cab ?
DO you hear any clicking in the cab when pushing the 4wd buttons ?
DO you hear the transfer case trying to shift into a 4wd mode ?
this information matters if not posted its going to be harder for members to help you
The front end isnt engaging. The transfer case locks and the actuator under the hood works perfect. The cable that runs to the front diff is NOT broken. It pulls like it should But the front still is not locking.
here this might help: common 4x4 problems
To me it sounds like something after the cable. Something can get out of alignment, i dont remember what exactly but i have read about it a few times on here. I think its covered in the link i gave you.
Edit: Does the actuator pull the cable 1/2-3/4 of an inch? if it pulls the cable more than that then theres something out of alignment but if it pulls less than that then you have a vacuum problem
