cant find what's causing the vibration
Old Aug 28, 2010 | 02:22 PM
bigbrown90's Avatar
bigbrown90 is on a distinguished road
Default cant find what's causing the vibration
I just finished my 4" lift kit and noticed immediately that at speeds over 20 mph a slight growl would arrise after letting off the gas (to coast), the growl grows louder at higher speeds. I assumed that my driveshaft was in a bind and measured my angles of the transfer case and at the rear differential and found a slight difference, long story short, i've tried 2.5 degree shims(growl still there) and 4 degree shims and now after the 4 degree shims there is alot more noticable vibtration and the growl still persists. Any and all info is appreciated, I ifeel like its a simple problem that i just cant get pin pointed.
Old Aug 28, 2010 | 03:10 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
So do you think its coming from your driveshaft? Is your truck aligned? And tires balanced? Just trying to get some more information first to help out
PROJECT85K5
Dec 6, 2009 10:55 PM
quik1964
Feb 18, 2009 09:42 AM
95blazer4wd
Feb 14, 2009 02:29 PM
05Blazin
Sep 11, 2008 06:53 PM
j1cs
Jan 15, 2007 05:03 PM
