Cant hold in road, almost wrecked.
Old Nov 23, 2012 | 06:04 PM
jbb421's Avatar
jbb421 is on a distinguished road
Default Cant hold in road, almost wrecked.
So i have a 96 4wd blazer 2dr with about 300k on it. ive lifted it 2 inches, replaced the idler arm, tierods, ragjoint, and passenger cv axle. its been doing fine but i was headed to work the ontherday on a little road hit a small bump, and got the steering wheel jerked out of my hand it went all over the road with a car in the oncoming lane thankfully i was able to get it back in my lane, and wasnt going fast (35ish). its been doing this for a little while now but never that bad. also when you take a left turn it will just keep turning and wont return back to center. Right turns are fine however.
If anyone can help i would really appreciate it.
Thanks Jbb sorry for the lack of grammar.
Old Nov 23, 2012 | 06:56 PM
chris015's Avatar
either gear box is bad,or ragjoint. Maybe a ball joint.
Old Nov 23, 2012 | 07:29 PM
jbb421's Avatar
Thanks for the reply... it has a brand new ragjoint on it, and im pretty sure i installed it correctly. All the balljoints have 300k on them so i guess thats the place to start? So does the steering box but with the key on engine off it turns the tires just fine and doesnt miss a beat. nor does it while running, It is abit sloppy steering wheel side even if i adjust it.
Old Nov 23, 2012 | 07:54 PM
richphotos's Avatar
300k on your ball joints? are you sure about this?
Old Nov 23, 2012 | 08:30 PM
chris015's Avatar
rich,mine has about that and they are original...they feel ok. One day i need to change em!
OP if you do go with balljoings stick with moog or something like that...balljoints is one of those "you get what you pay for" deals.
Old Nov 23, 2012 | 09:17 PM
jbb421's Avatar
Yup their still factory, and the truck has damn near 300k on it the passenger side felt fine when i replaced the cv, but i dunno where to start and balljoint seem to sound good atm even though i can only afford two atm.
Old Nov 24, 2012 | 07:44 AM
coolasice's Avatar
coolasice will become famous soon enough
did you adjust the steering gearbox? the tension screw with the allen head? if so it may be too tight and causing your sticking steering.
Old Nov 24, 2012 | 05:51 PM
jbb421's Avatar
yes i did but i loosened it up abit to where it wasnt sticking a few weeks ago.
Old Nov 24, 2012 | 06:38 PM
chris015's Avatar
i learned to never touch that screw. too tight and you'll kill it. without knowing till its too late.
Old Nov 24, 2012 | 07:14 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Pitmen arm?
