Which is cheaper?
Old Mar 9, 2008 | 11:01 PM
TripleBlackBlazer's Avatar
Default RE: Which is cheaper?
What trucks had the G80 with 3.73s or 4.10s? Bravada?
Old Mar 10, 2008 | 05:20 PM
Default Pros/Cons
Bump for new question.
What are the pros/cons of welding my spider gears in place to create a locker? Increased tire wear? Has anybody seen or done this before? Any reliability issues with the welds breaking?
Old Mar 10, 2008 | 05:29 PM
WolfPack's Avatar
Default RE: Pros/Cons
I thought there was another thread on this a little while back..I can't remember what was decided.
I suggested just getting a mini-spool. Much cheaper and guraunteed not to pop a weld and destroy the rear axle. Althought I imagine a non-differential-ed rear end would give a bit of a hopping feeling as the inside tire wraps on itself and the outside drags.
Pretty terrible for a road vehicle that likes parking lots
Old Mar 10, 2008 | 07:09 PM
Powertrax locker, anything more cost effective than that out there? How can I find out if I have 26 or 28 splines?
Old Mar 10, 2008 | 08:14 PM
WolfPack's Avatar
The only thing I see cheaper is the Detroit E-Z locker. Jigg's got it on the Lockers and Gears page at Synergy Offroad. The only problem I see is he's got it listed for a 30 spline (probably ZR2?) and you're asking if you have 26 or 28
The Powertrax looks pretty good, but I stand by the junkyard G80
Old Mar 10, 2008 | 11:22 PM
$100 (with shipping) for a freshly pulled G80 sound good? 7.5" and 7.625" rears the same or not? If it came with 3.42's can I still put 3.08's in it?
If this is a viable option I may go this route and keep my 3.42's!
EDIT: Ah man I didn't realize the auction ended in an hour. Think I should hop on this or what? $100 is definitely do-able at this point in time, much better than $300+.
Old Mar 11, 2008 | 12:20 AM
WolfPack's Avatar
It sounds pretty good..I just don't want you to drop 76 bucks or whatever on our combined guess work!!
And you should be able to put 3.08s on it, 'cause all that changes for that is the big ring gear and the pinion...nothing inside the locker right?
And if you miss this one, you should be able to contact the seller..it looks like he's sold a few of these . I might have to get myself one eventually
Edit: I am also slowly realizing I absolutely suck at ebay. I can't find anything. I tried to look at body lifts..got some stuff about home gyms [:@]...only found one carpart under G80..lol
Old Mar 11, 2008 | 12:27 AM
Found this one, no guesswork involved: POWERTRAX.
7.625" rear? Check
28 spline count? Check
Cheap (as of now)? Check
I will be staying with 3.42's.
EDIT: Now I just need to worry about what else goes with it. If it drops into the carrier, will I need new bearings/races/etc. or is that only for a new ring/pinion?
Old Mar 11, 2008 | 12:30 AM
WolfPack's Avatar
Oh good find. Also a bit more time for you to decide!
ANDDDD...67% stronger than titanium! I dunno though...I might hold out for a locker that was at least 68% stronger than titanium
Old Mar 11, 2008 | 02:57 AM
thegr81's Avatar
Its a tuff decision but im siding with wolfpack on this holding out for a locker would be beneficial to you more if future plans are to do a big lift for offroad or in case of a increase in power its ready to go to handle it!!
