Clunk?
So last night i was driving around and i relized that when i have my wheel cut completly to the left or the right and go foward or reverse theres is a kind of clunking noise. Its only when it is cut, i have stock rims and toyo tires 235/75/r15 so im pretty sure there not rubbing. Any ideas?
Jack the front tires off the ground and shake the tire from 12 and 6 o'clock in a rocking motion. If there's movement, you've likely got a bad ball joint or two. Next shake the tire from 9 and 3 o'clock in a left to right rocking motion. If there's play, look underneath at the steering linkage for movement.
raviz
Nov 21, 2006 09:54 AM
