Cracking like noise when turning right
Old Jul 27, 2017 | 03:22 PM
Chevy3blazer's Avatar
Chevy3blazer is on a distinguished road
Default Cracking like noise when turning right
Hi, I just got new idler arms, Pittman arms, and steering column put on my 1999 2wd Chevy Blazer, but I noticed a cracking lik noise when I turn right. It's embarrassing. I was wondering if the new idler arm or something may need some grease or lube, if so what kind? But if that's not the case, what should I do to stop he weird noise?
Old Jul 30, 2017 | 06:19 AM
Everything tightened up to spec?
Lift the front (safely on safe stands) and have someone turn, then look and listen in for the crack.
Always at the same angle?
When turning to one side or also the other?
Have someone turn slowly and look at all the moving parts. Interference somewhere? Does it catch on something?
This should help with narrowing down the place
Old Jul 30, 2017 | 09:37 PM
Yes everything is tightened. It always makes the noise when turning to the right.?
Old Aug 9, 2017 | 02:23 AM
I'd safely lift the car in front. On the secured car try turning and listen for the noise with engine off.
Hopefully it is doing it when lifted.
Old Aug 14, 2017 | 08:48 AM
10-78 edac's Avatar
10-78 edac is on a distinguished road
sounds like a cracked sway bar end
Old Aug 15, 2017 | 04:43 AM
With a bit of luck just the rubber gone in the bracket.
Still easiest way to find out is to go looking.
ComputerNerdBD
Oct 25, 2013 03:14 PM
bella313
Jul 14, 2011 06:08 PM
vankuen
Mar 24, 2008 09:24 AM
ben_b
Aug 3, 2007 01:13 AM
cmblackburn
Apr 11, 2007 10:30 PM
