CV Axle replacement
Old Oct 4, 2008 | 04:42 PM
bexxdad's Avatar
bexxdad is an unknown quantity at this point
Default CV Axle replacement
Hi Everyone,
I need some help. I'm replacing my CV axle on my 2000 Blazer. I got the bearing hub off and the ball joints disconected. Pulled on the CV Axle ( not hard ) and about 2/3 of it came out ( just to the 2nd boot ). Any ideas how to get the rest of it out?
Old Oct 4, 2008 | 05:21 PM
watsonmt's Avatar
watsonmt is an unknown quantity at this point
Default RE: CV Axle replacement
i might be wrong but isnt there only 2 boots on the cv axle .at least that all there is on my older one, i think the rest is just the straight shaft that goes into the diff.
Old Oct 4, 2008 | 06:47 PM
bexxdad's Avatar
your right, just wanted to express how much was left in. it's the shaft and the part the boot attaches to. any idea how to get it out? I tried getting a pry bar behind it, and hitting it while pulling as suggested in the manual i have but no luck.
Old Oct 4, 2008 | 07:03 PM
watsonmt's Avatar
oh i get it ok well if youve takin off all of the bolts holding it to the shaft and then i had to take off the spindel from both ball joints and the tie rod to get teh room to get it out the i just put in a bar and hit it on the seem it will come apart but there gets to be a lot of rust in there so alot of hit and some good hits all around it and a few to the front and back should pop it off i know its hard i just did it two weeks ago.
Old Oct 4, 2008 | 08:32 PM
bexxdad's Avatar
OK thanks, I'll start back up in the morning. Been a long frustrating day.
Old Oct 5, 2008 | 08:25 AM
If you are trying to remove what is left of the inner CV shaft from the diff, typically, a block of wood and a 5lb hammer help out with this. There is a detent ring inside that helps retain the shaft. It can sometimes make it quite difficult to disengage the half shaft from the diff. Take a couple of hits on the CV shaft, then rotate it and hit it at another location.
Old Oct 5, 2008 | 12:05 PM
bexxdad's Avatar
[:@]Difficult is an understatement! after beating the hell out of it with a 20 lb sledge and a block of wood it still wouldn't come out. I finally got it out putting a 4 ft crowbar behind it. Not including the time it took to get that out, the total job was only about 2 1/2 hours including stopping for an occasional cigarette or beer. Anyone attempting this without being a mechanic ( I am not a mechanic ) should know that it's actually fairly easy to do. I felt a great sense of accomplishment knowing how much I saved by doing it myself. Also the new cv axle was $64 at a local parts store plus the core charge.
chowell
Mar 6, 2021 09:47 PM
thrandall
May 3, 2013 04:54 PM
blajeans
Jan 9, 2013 12:58 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
