CV Half shaft assembly - OEM or no?
Old Feb 7, 2015 | 03:12 AM
Bolbol's Avatar
Bolbol is on a distinguished road
Default CV Half shaft assembly - OEM or no?
2001 Chevy Blazer 4wd LT
I've finally found that the cause of the clicking noise I get when turning my wheels is due to the CV joints..
I went on rock auto and found that the whole assembly seems to cost way less and so I want to buy the whole thing instead but I am not sure what brand to go with
There are a lot of brands with cheaper prices and the names are API, Surtrack, cardone select, A-1 cardone, EMPI, and finally AC Delco.
All these brands items are cheaper than $100s, some even less than $50 but AC Delco is 260 for front left and 470 for front right..
I would like to know if its worth the money? I feel like original parts are good but the fact that its the same part that failed makes me wonder if theres a possibility that the others could have been made with better quality or are longer lasting.
Also I noticed there is an option for "High Rider" with each brand. What does that mean?
Old Feb 8, 2015 | 08:38 AM
TZFBird's Avatar
TZFBird is on a distinguished road
High rider is going to be for the ZR2. They have longer control arms due to more suspension lift.
Cardone Select is going to be a new unit and A1 Cardone a remanufactured unit. As far as the other brands, if it's under $100 it will most likely be a repaired axle vs. all new materials.
Old Feb 8, 2015 | 07:51 PM
Bolbol's Avatar
A1 Cardone is the more expensive unit too.. Do you guys think its worth it? I don't wanna be spending that much every few months to replace an axle
Old Feb 9, 2015 | 06:08 PM
xtrmes10's Avatar
xtrmes10 is on a distinguished road
Just go to your local NAPA if you have one around. $77. with a lifetime warranty. I have them in mine.
skygodtj
Jun 10, 2012 09:41 AM
ddog800
14
Feb 16, 2011 03:01 PM
manekDC2_
Nov 5, 2010 02:55 AM
