different gear ratios front / rear diffs ?
Old Mar 5, 2011 | 04:38 PM
jamies96's Avatar
jamies96 is on a distinguished road
Default different gear ratios front / rear diffs ?
Hello i have a 1999 blazer with a blown rear diff and replaced the whole rear end with a 2001 blazer.The question is what if the front diff ratio is different than the rear? would this f the transfer case when i 4x4? when i bought the replacement from the wrecker he said it was compatible but he was a bit of a clown so now im not sure.
Old Mar 5, 2011 | 04:50 PM
69chevelle's Avatar
69chevelle is on a distinguished road
yes it will, and your vehicle wont handle at all. and won't want to roll as the front or back would have to spinn faster or slower then the other
most common is 3.42's you will likely be the same.
Old Mar 5, 2011 | 05:01 PM
Benedict1337's Avatar
yea he's right check your rpo codes in your truck in the glove box look for either gu6 or gt4, gu6 is 3.42 gears, and gt4 is 3.73, not sure how you can check the rear gears unless the dude from the auto salvage knows the specs to the blazer it came off of.
Old Mar 5, 2011 | 06:53 PM
01vortec's Avatar
01vortec is an unknown quantity at this point
it'll run and drive fine.
Unless you put it into 4wd
Old Mar 6, 2011 | 12:17 PM
abig84's Avatar
Had a truck like this while I was swapping axles. I only used 4x4 when I got stuck in the mud. Basically if u use it on the street it'll just be like holding down the brakes
GryphonBlaze
Dec 30, 2011 09:33 PM
Tony H
16
Jul 30, 2010 09:26 AM
Boyer2011
Feb 28, 2009 10:20 AM
ababion
Mar 14, 2008 01:07 AM
ivannj
Aug 20, 2006 07:01 AM
