Different heights on front w/w !!!
Somewhat normal as these trucks age. Seems the passenger side torsion bars like to sag. If you want to bring the passenger side up, but run out of adjustment, you may have to look at getting new torsion bars ($$$).
i was pondering a small lift...2 inch at the most. and saw that the d/s bolt head was flush with the cross member and the p/s bolt was sticking out. kinda makes me think that some previous owner messed with it for alignment or to level it out due to a huge driver ect.
It's been my experience that just about every quick lube/ speed tire place says that balljoints/pitman arm/idler arm are bad, and they can't align until replaced. Each time I've had my trusty mechanic (one time the dealer) verify, and they were fine.
Not saying that you have no need for new balljoints, but definitely get a second opinion, and definitely price shop
Balljoints can get pricey...
As for your torsion bolts...I've heard a couple aligment shops/techs mention that when doing an alignment they will often adjust the bolts to get it to sit level before alignment.. So it's not always an indication of a previous owner cranking it up for lift
Balljoints can get pricey...As for your torsion bolts...I've heard a couple aligment shops/techs mention that when doing an alignment they will often adjust the bolts to get it to sit level before alignment.. So it's not always an indication of a previous owner cranking it up for lift
thereverendbill
Jun 19, 2010 10:12 PM
LemonBlazer
Lifting Tech
Jun 22, 2009 10:47 PM
