diif problems
yesterday i was driving and my truck started shaking around 40-45mph..when i got home i noticed that my diff is leaking from the cover..today i did a better inspection and noticed it is also leaking from where the drive shaft and rearend meet..i tried to add some fluid but i can get my fill plug out soaked in pb blaster and hit it with some heat and now i stripped it from trying after heating it up..im stuck now i could replace the gasket but how will i fill it back up?any ideas?
You have several options. Remove the cover and drill and tap a new plug using and "pipe tap" ( a tapered tap ) or taking it to someone and have them weld a new bung on or buying a new cover. I would replace the seal at the same time as the dif service and check out your u joints as well. Hope that helps.
there is no drain plug or fill plug on the cover..its on the passenger side on the driveshaft side of the diff
okay i got the fill plug out and then i added oil and it still shakes...could it be my spider gear or am i better off buying a new rear end?i found one at the junkyard for $236 my u joints and driveshaft are looking good..i find it crazy for it leak at the drive shaft and the cover gasket..please help
Have you checked your tires?
