diif problems
Old Aug 27, 2012 | 02:16 PM
p.o.s.blazer420's Avatar
p.o.s.blazer420 is on a distinguished road
Default diif problems
yesterday i was driving and my truck started shaking around 40-45mph..when i got home i noticed that my diff is leaking from the cover..today i did a better inspection and noticed it is also leaking from where the drive shaft and rearend meet..i tried to add some fluid but i can get my fill plug out soaked in pb blaster and hit it with some heat and now i stripped it from trying after heating it up..im stuck now i could replace the gasket but how will i fill it back up?any ideas?
Old Aug 27, 2012 | 03:11 PM
50lb_cat's Avatar
You have several options. Remove the cover and drill and tap a new plug using and "pipe tap" ( a tapered tap ) or taking it to someone and have them weld a new bung on or buying a new cover. I would replace the seal at the same time as the dif service and check out your u joints as well. Hope that helps.
Old Aug 27, 2012 | 03:15 PM
there is no drain plug or fill plug on the cover..its on the passenger side on the driveshaft side of the diff
Old Aug 28, 2012 | 09:58 AM
okay i got the fill plug out and then i added oil and it still shakes...could it be my spider gear or am i better off buying a new rear end?i found one at the junkyard for $236 my u joints and driveshaft are looking good..i find it crazy for it leak at the drive shaft and the cover gasket..please help
Old Aug 28, 2012 | 11:42 AM
50lb_cat's Avatar
Have you checked your tires?
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
