Doggonnit! Idler arm play?
Old Sep 23, 2012 | 06:29 AM
chris015's Avatar
haha no! the hardest part is keeping the bolts from falling off into the frame then having to fish them out of that small hole with your pinky. Ive got a 2" extensions and 2 sockets in my frame now that's always going to be there lol.
if you have a friend that can help,have him hold the bolts in the frame while you get the new one on and the nuts started. everything else is gravy. Other then getting the pickle fork in the right angle to have room to swing at it.
My new issue (well,its always been there) is i have instant response when i barely turn my steering wheel to the left,but a 1" delay of play when i turn it to the right. Everything on front is pretty much tight. Im guessing rag joint or steering box play. ive got a short in my steering column somewhere thats causing my front blinker not to work unless i turn my wheel a bit,i may change out the whole thing (which will fix my steering wheel slop from the loose bolts that always backs out) and it'll fix my short. I might do the jeep shaft swap then too,so while its out i can drill a hole for a safety bolt to run through it.
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
