dont think it is like the other 4x4 questions
i know my 4 wheel drive does not work so it will cost a lot to fix it and i dont have that much money so does that system make my gas milage go down even if i dont use it? and if it does can i get it taken out? thanks
RE: dont think it is like the other 4x4 questions
i dont think it will affect your mileage. You may be able to get a littlemore mpgif you removed 4wd parts (weight reduction) not sure if that helps
You can't really remove any 4wd parts other than the driveshaft from the t-case to the front diff.
It's not built to run without them. |
