#' drop block u-bolts do not fit
Old Sep 29, 2008 | 04:30 PM
Bad Ramer Jamer's Avatar
Bad Ramer Jamer is an unknown quantity at this point
Default #' drop block u-bolts do not fit
Imtrying to install Belltech 3" drop blocks. The u-bolts are for a 3" axle tube. Mine is a 2.5" axle. At first Belltech gave me a part # that I needed to order through Summit. Now they say it's a good #,,,but they cant supply the part. "Just squeeze it together". Ya right. Even if I did get it to go in the lower bracket,,wouldn't there be too much slop at the top. Im affraid it would move. Have any of you guys run into this before. Thanks.[/align]
Old Sep 29, 2008 | 04:38 PM
TripleBlackBlazer's Avatar
Default RE: # drop block u-bolts do not fit
Yes I actually have while using universal drop blocks from Summit. Ended up going to a local leaf spring shop to have new u-bolts made. I think it was in the $10-20 range for 4.
Old Oct 5, 2008 | 05:37 PM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
auto zone sells drop/lift block kits... there a perfect fit.. lowering is my speacilty
drummerdude
Nov 13, 2009 09:11 PM
wlorton
Tires and Wheels
Aug 23, 2009 06:12 PM
lil_blazin
May 10, 2009 05:20 PM
j_snake
Tires and Wheels
Mar 27, 2009 02:02 AM
Bad Ramer Jamer
Suspension Tech
Sep 25, 2008 04:22 PM
