Dropping a 99 4x4 Blazer WITH REMOVED FRONT DRIVESHAFT
Old May 12, 2013 | 11:20 PM
ChromeJerome's Avatar
ChromeJerome is on a distinguished road
Lightbulb Dropping a 99 4x4 Blazer WITH REMOVED FRONT DRIVESHAFT
I have a 1999 Chevy Blazer 4D LS 4x4 that is currently dropped 2" all around, using pinion angled blocks on the rear leaf springs, and dropped in the front by removing the 4wd driveshaft. So essentially, it is a 2wd blazer. I was wanting to know if now I could take the same approach as people with 2wd blazers, or are there still restrictions on how I can go about dropping it further since it used to be a 4wd? I'm looking to drop it 2-3 more inches (4-5 total) all around, any tips/ideas on how I could do this? Not looking to buy cheap $20 lowering springs off of ebay or anything, I know I will sacrifice some ride quality, but I want to do it right. Also, should I look into stiffer shocks to prevent rubbing or scraping when going over bumps?
Old May 13, 2013 | 04:07 PM
*Bump
Old May 13, 2013 | 10:20 PM
LeWhite's Avatar
I think the control arms mount lower on a 4wd so you are limited to , my guess, 3 inch inthe front . If you get more than 3 inthe back you have to take one bulb off the bumper. 4inch and you are getting close to notch requirement. Be careful in the back with the brake line, it needs to be looped out away from the frame.
Dont pay too much attention to the lowered 4x4 haters. Unless they pay your vehicle registration
Old May 14, 2013 | 09:10 AM
El_Beautor's Avatar
You can lower the front using the T-bars. You can't use lowering springs in the front because a 4x4 Blazer doesn't use coil springs. You'll just be doing the reverse of a T-bar lift. You want to turn the T-bar bolts further out. Check the front control arms and leave yourself at least a little room before they hit the bump stops. Lowering it you'll likely end up with having very limited upward travel as the control arms will hit the bump stops much sooner. As with any time you change the front end geometry you'll need to get a wheel alignment so you don't end up chewing through your tires. If you need more info about adjusting your torsion bars a quick search will give you tons of info. I know there's a how-to in the lifting tech section, and may be one in the lowering section too. I'm personally not interested in lowering so I haven't checked there.
Old May 15, 2013 | 11:16 PM
Thanks for the help and input guys, not just gonna say it's easier to do a 2wd and go the route everyone goes, gotta be different sometime.
gitch93
Jan 23, 2013 04:51 PM
chcknugget
Oct 24, 2012 08:25 AM
importsky22
Aug 27, 2012 07:14 AM
96-blazer
Lowering Tech
13
Jul 24, 2012 07:53 AM
hypertek
Jul 21, 2011 10:07 PM
