e-brake issue
Old Apr 19, 2007 | 08:24 PM
drperry's Avatar
Default e-brake issue
A little while ago, my e-brake stopped working properly... I can't stop the vehicle from rolling backwards anymore, no matter how far the e-brake pedal is pressed...
Going forwards, the e-brake works great, hardly need to press the pedal at all to get the truck to stay in place...
Do I need adjustment, or new pads, or what?
Old Apr 20, 2007 | 04:39 AM
Chevy Lover's Avatar
Default RE: e-brake issue
You probably need a shoe adjustment. Do you have rear disc or drum brakes and what's your milage on the truck?
I would start by inspecting the park brake shoes.
Do not adjust the cable.....the brake shoe adjustment is the primary adjustment and usually does the trick.
I'm thinking that you have rear disc brakes, witch means removing the calipers and rear brake rotors to inspect the parking brake shoes. If that's the case there is a star wheel adjustment in there and if the shoes are ok, adjust the adjuster a little at a time, fitting the rotor over after evry adjustment until there is the slightest drag of the rotor on the park brake shoes. Just be surenot to over-tighten the shoes as you should still be able to spin the wheel by hand.
Old Apr 20, 2007 | 08:49 AM
drperry's Avatar
I'm 99% sure it's disc brakes... I forget at the moment, lol.
I have about 53,500 klicks on it...
I know that after 3 - 5 clicks the truck doesn't roll forward at all on my driveway... If it's done snowing and dried up, I'll try and take a look tomorrow...
Old Apr 20, 2007 | 06:02 PM
20Blazer00's Avatar
Here is a photo from Napa Online as to what an e-brake shoe looks like for the rear disc brake on an s10 Blazer this is from a listed 2003, it would not show a 2005...but they should be the same....also listed at $90
[IMG]local://upfiles/1127/FFD4BE2D1CD7457089DA4F6F5D4EA6DD.jpg[/IMG]
Old Apr 20, 2007 | 06:46 PM
drperry's Avatar
They don't show the 2005, because 2003, as far as I know is when they stopped being sold in the US...
But thanks for the info! If they're worn to poop, then at least I know I don't have to buy them from the stealership...
zach bjorge
Mar 17, 2011 06:49 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
dashyman
Jan 12, 2007 11:28 AM
