Floating axle?
Old Jan 29, 2009 | 09:29 PM
jackedUPk5's Avatar
jackedUPk5 is an unknown quantity at this point
Default Floating axle?
Looking at buying an old K20 pickup..
Not exactly sure on what it means by having a floating 1 ton axle in the rear...?
I know what an axle is... But floating? Someone have an explanation and comparison to something else?
Old Jan 29, 2009 | 09:36 PM
rriddle3's Avatar
Default RE: Floating axle?
Does this article help out?
Old Jan 29, 2009 | 09:42 PM
WolfPack's Avatar
That article was very helpful for me i'll say that much
Basically, semi-floating is what most people are used to. Wheel bolts to the axle flange, a few bolts, and wheels on. This means the axle shaft is handling the weight of the vehicle, as well as the power from the drive line.
Full floating is on larger trucks or heavy duty axles. The axle shaft only handles power from the drivetrain. There is a full outer bearing at the end of the axle tube that bolts to the wheel that actually supports the weight of the truck, through the axle housing. The shaft is then bolted to the wheel through the inner bearing. The coolest thing I think is that you can swap an axle shaft with the wheel still on, and the truck on the ground..wild..
But read that article for real...its good!
Old Jan 29, 2009 | 09:44 PM
jackedUPk5's Avatar
Yeah, that helped clear alot up!
Thanks man, I appreciate it.
Old Jan 29, 2009 | 11:45 PM
I had a 14FF axle up until my dad decided to scrap it! And a matching D60 too!
Old Jan 29, 2009 | 11:48 PM
WolfPack's Avatar
[&o]
I want a 14bolt on the blazer...just to be like yea...its a 14bolt. hahhhh
Old Jan 29, 2009 | 11:54 PM
They are heavy!
Redtortoise38
Jun 12, 2015 04:13 AM
blajeans
Jan 9, 2013 12:58 PM
TommySkillz
Sep 17, 2010 09:49 PM
ComputerNerdBD
Apr 29, 2010 08:10 AM
BLUEMEANIE
Suspension Tech
Apr 17, 2008 07:36 AM
