Front axle issue
Old Sep 8, 2023 | 08:15 PM
BlazerCalledGoldie's Avatar
BlazerCalledGoldie is on a distinguished road
Default Front axle issue
I just replaced the vacuum lines that control the vacuum actuator, and the vacuum actuator works. The transfer case shifts into gear as well. The cable going to the axle barely moves, and the axle does not lock. I even lifted a wheel off the ground to rotate it while trying to manually engage the axle, but it does not move enough to spline. Does this mean I need to take the axle out and rebuild it?
Old Sep 8, 2023 | 11:31 PM
Have you disconnected the cable from the axle to make sure the cable itself is not stuck?
Old Sep 9, 2023 | 05:56 PM
03blaZeR2's Avatar
03blaZeR2 is on a distinguished road
Good time for a bravada passenger side axle upgrade. Get rid of all that vacuum at the axle. The actuator and the 2 piece shaft. No this does not make your truck awd or create binding in the front end.
Old Sep 10, 2023 | 09:30 AM
Sure, it doesn't create binding, but the transfer case will get more wear on it.
Old Sep 10, 2023 | 09:32 AM
the cable does move slightly, and I had someone listen for anything moving in the axle,, and we can hear the collar move and hit the shaft, but it feels like the shaft on the inside itself is not spinning.
To disconnect the line to check it, do I unbolt the 3 bolt housing, or do I spin off the nut on the cable?
Old Sep 10, 2023 | 09:58 AM
03blaZeR2's Avatar
if that’s what you think and your reason for not doing it. That’s fine. It’s your truck.
you must not realize your t case is always running every time tour truck moves. So does the front axle. Yes it free spins all the time. Just giving you an idea to eliminate the Issues you have. Noting more nothing less. It’s your choice on what to do.
Old Sep 22, 2023 | 01:19 PM
Default Found the issue
The diff grenade itself. I know it wasn't me as well, as I got the thing a few months ago. I have a new axle on the way. 👍
v8449
Dec 14, 2020 06:48 AM
jrm000kc
Dec 1, 2018 06:00 AM
Esty
Jan 22, 2012 08:32 AM
mobydick38
Jan 4, 2010 06:54 AM
dgh91
Jun 20, 2009 08:26 AM
