Front CV Axle replace
Old Aug 17, 2007 | 10:16 AM
Shizer's Avatar
Shizer is an unknown quantity at this point
Default Front CV Axle replace
I removed my old cv axle finialy and I am trying to get my new one on. But no matter what angle I try no luck. Does it have the instructions on how to do it in the books at auto zone?
Old Aug 17, 2007 | 11:22 AM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: Front CV Axle replace
Hey, glad ya finally got that thing out. Curious how did ya get it out? Grinder, welder, other? Last i heard it was being a pain in the rear. Anyways to get the new cv in, yeah its a pain. I assume you cant get it to seat in the diff right? If thats the case it helps to have a buddy hold it for ya while ya twist the cv and put pressure on it to get it so seat right. Takes some time but it will pop right in. Other thing to check is that you have the right cv. The left and right side are different and each will only slide in on their correct side. Easiest way to tell is to look at the end that goes in the diff and then at the tube to the diff and make sure that its the correct end needed.
Old Aug 17, 2007 | 12:19 PM
Shizer's Avatar
I usesd a grinder and cut the last two bolt heads off. Just going to leave the rest of the bolt in their for now tell it causes a problem
chowell
Mar 6, 2021 09:47 PM
BoDog89
Mar 26, 2013 09:36 PM
YJ Wralph
29
Feb 12, 2013 01:41 PM
blajeans
Jan 9, 2013 12:58 PM
jcrocket
Sep 18, 2010 06:01 PM
