front diff and rear axle zr2 to 4 door
Old Feb 5, 2011 | 12:41 PM
simmonsnick's Avatar
simmonsnick is on a distinguished road
Default front diff and rear axle zr2 to 4 door
can i swap my front diff and rear end to zr2 rear end and front diff ? right the rear end from a zr2 is wider then a 4 door ? i know this has been asked before.
Old Feb 5, 2011 | 01:17 PM
rriddle3's Avatar
Originally Posted by simmonsnick
...i know this has been asked before.
...and the answer you saw was what?
Old Feb 5, 2011 | 01:42 PM
dont know didnt read it wasnt interested at that time but thanks for the help !!
Old Feb 5, 2011 | 01:59 PM
Benedict1337's Avatar
wolfpack and rob44_90 did the rear end swap, can't remember if one of them did the front too or not..
Old Feb 5, 2011 | 02:04 PM
i would love to swap just the rear but not sure what my gears are or if the housing is the same on the zr2 rear end so i can just swap my gears in to it.
Old Feb 5, 2011 | 02:07 PM
almost all zr2's are 3.73 gears. and you can get 3.73 gears for your front some regular blazers came with them. check your rpo codes in your glovebox, gu6 is 3.42 and gt4 is 3.73, so if you have 3.73's you could bolt up the rear axle and not even touch your front end
Old Feb 5, 2011 | 02:27 PM
thank you so much i have 3.73 gears so i will now find a zr2 rear end THANKS AGAIN!!!
Old Feb 5, 2011 | 03:07 PM
just remember zr2 axles are 4" longer than regular blazer axles (stick out 2" more than your axle on each side). They are also 8.5" instead of the non zr2 7.65" if you ever want to get something better than the g80 differential make sure you get the 8.5" size. good luck finding a zr2 axle, I've been on the hunt for a while...
Old Feb 5, 2011 | 05:50 PM
already found sum at a local salvage yard!! yeah, i know that they are wider thats the reason i want it but didnt know it was bigger so thank you once again for your help!!
goldnugget
Feb 25, 2022 09:56 AM
97GMC
Nov 10, 2014 09:51 AM
blajeans
Jan 9, 2013 12:58 PM
GrammySr
Jul 12, 2012 11:25 AM
rippert1
Jan 20, 2010 06:01 AM
