Front Diff Service, good then bad.`
I began to service the front diff in my 2000 Diamond Edition today. after getting it in the air a bit and crawling under I found that it had a drain plug! After draining the fluid I inserted the plug, tightened it with fingers, then with the first turn of a wrench the threads in the housing stripped.
What are my options here? Is it time to tap and get a new plug?
Right now I am thinking of tapping maybe 2 sizes bigger, then thread locking and never using it again. Any other ideas?
your best bet without removing the whole front diff would be to drill tap and install a heli coil. than to get the metal shavings out pump oil thru the oil fill to flush the metal out the drain plug. this is your cheapest soloution with out replacing the whole diff.
I would rather just remove it than risk getting metal shavings in the diff. It doesn't take much longer and you will have no worries that way. With diff oil being so heavy I wouldn't trust it to flush everything good enough. IMO.
no in theory u shouldnt need to seal the threads (other then lock tite the helicoil only like war00 said) cause there should be a sealing washer around the bolt if anything replace that to for good measures.
Most auto parts carry self tapping repair plugs that are a slightly larger diameter that are made just for this problem. I've used them a few times without any problems. They also have a built in magnet to catch any metal shavings from cutting the new threads. I think that would be your easiest option.
the front diff is aluminum, so the magnetic plug wont be of any
good use, I have used heavy bearing grease while tapping a hole to hold
the shaving, apply heavily to both the tap and the area being tapped,
then wipe clean when finished....
