front diff shaft question.
Old Aug 10, 2011 | 03:22 PM
warthogdriver's Avatar
Default front diff shaft question.
i am looking to replace the seal on the end of the front shaft leading to the cv axle at the wheel.
i was also going to replace that bearing while i was at it.
what is the proper name for that bearing??
i have called several stores and have gotten several diff names...go figure.
so now i dont know what i am looking for name wise.
i was looking at rock auto and found this. \/ \/ \/ \/
also, which one of these would be it?
99 4x is the target vehicle....thanks guys.
also, any advice for getting the cv shaft off the splined shaft?
i know its on there good...when i did the lift i pulled the cv and splined together and then i had trouble with that washer at the diff end of the tube.
Old Aug 10, 2011 | 04:41 PM
Which side? The driver side bearing comes out from the inside if I remember correctly.
You can check Compnine.com's diagrams to find the name & OE part number for the appropriate bearing.
As far as releasing the CV shaft from the axle shaft, a block of wood & a 5lb hammer works quite well at this. Getting access can be a pain though.
Old Aug 10, 2011 | 05:55 PM
pass side is giving me troubles....
thanks for the site and the tip on the cv shaft.
is there a way to get it all back together if the spline shaft comes out and that washer slips...short of tearing apart? i doubt it but...mehhhh
edit***************
ok, spent sometime searching the net.
found this beauty....
it lists timken part equivalent for all bearings!!!!
http://www.who-sells-it.com/images/c.../pdf_21318.pdf
check it out.
and by the way my part is
ac delco 26053326
thanks again.
Old Aug 16, 2011 | 09:16 PM
****bump********
ok, well i now have my parts and a plan ( i think)
what i am asking is, is there a way to do this without pulling the passenger axle tube?
i can do it, just looking for been there done that advice....or quick ways to do this.
seal looks like no problem....bearing i know spline shaft should be removed.
is there a way to keep that "thrust" washer in place or put it back up when the shaft should go back in?
when i did my lift i accidentally pulled the spline and cv shafts then thought "oh $h!t" when i couldnt get it back in then noticed that the "thrust" washer had fallen out of place. so i tore it all apart and crossed my fingers i did it right...i hate moments like that.
thanks guys.
Old Aug 17, 2011 | 07:21 AM
If you are only replacing the outer bearing & seal, it can be done without pulling the extension tube. The problem is that space is quite limited with the extension axle in the middle of things.
As far as the plastic retaining ring goes (I think that's what you are calling a washer), it is there to hold the connection together. It fits into a groove inside the female spline of the CV shaft. You can get new ones fairly cheap from the dealer, I believe that original PN was 14041989; check with the parts counter for an updated reference.
Old Aug 17, 2011 | 01:10 PM
thank you for the info. always appreciated.
i will post back after this weekend when i get the job done.
thanks again.
Old Aug 17, 2011 | 08:02 PM
okiedoak20's Avatar
Wart,
Please try to get so pics, if you can so the rest of us con see whats happining
Thanks
Old Aug 17, 2011 | 08:32 PM
can do on the pics....there isnt much i do without pics.
always glad to give back.
Old Dec 12, 2011 | 06:56 PM
alpinesubs's Avatar
alpinesubs is on a distinguished road
I'm doing the same thing on my truck right now. I got the seal out easy put how did you get that bearing out without pulling the shaft? It seems to be in there pretty good........
Old Dec 13, 2011 | 07:56 AM
i used a slide hammer....also did a small write up...
this should help a little
https://blazerforum.com/forum/articl...le-seal-62365/
Twip
Aug 17, 2013 10:38 PM
bertrenolds
Dec 16, 2012 08:16 PM
VonBerry
Oct 15, 2010 11:52 AM
Tony H
Sep 7, 2010 07:45 AM
ComputerNerdBD
Mar 18, 2009 06:13 PM
