Front Differential swap?
Old Feb 28, 2010 | 07:55 AM
19skip63's Avatar
19skip63 is on a distinguished road
Default Front Differential swap?
Will a front differential from a 83 fit in a 93? or are at least the parts inside the same?
Old Feb 28, 2010 | 08:40 AM
I do not think there were any design changes in that range, but you would probably want to check with some kind of interchange list first. Most junkyards have access to such a setup. You would need to make sure that the gear ratio matched.
Old Feb 28, 2010 | 09:50 AM
19skip63's Avatar
Default gear ratio
Is it stamped somewhere on the diff or where do I find the ratio?
Old Feb 28, 2010 | 11:37 AM
TripleBlackBlazer's Avatar
The easy way is to check RPO codes for both vehicles.
Gear ratio codes usually start with G:
GU2 2:73 ratio
GU4 3: 08 ratio
GU5 3:23 ratio
GU6 3:42 ratio
GT4 3:73 ratio
GT5 4:10 ratio
Just make sure your donor truck has the same code.There is a manual way to check where you count driveshaft turns versus CV shaft turns but I am unsure of the details of that and not sure how it would work on a front diff.
Old Feb 28, 2010 | 03:47 PM
19skip63's Avatar
Default Another stupid question
Where do I find the RPO code?
Old Feb 28, 2010 | 03:51 PM
RPO sticker inside the glove box or plug your VIN into compnine.com's VIN decoder.
Old Feb 28, 2010 | 04:10 PM
neo71665's Avatar
That compnine.com doesn't go very far back, no list for my 91 or 87
YJ Wralph
29
Feb 12, 2013 01:41 PM
Drew4711
Oct 6, 2012 12:47 PM
shawn 34
Aug 15, 2009 11:38 AM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
lilred67ddgt
Dec 7, 2005 02:55 PM
