-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Front drive shaft cv boot (https://blazerforum.com/forum/steering-suspension-drivetrain-36/front-drive-shaft-cv-boot-70556/)
warthogdriver May 8, 2012 03:07 PM
I searched and called around..does anyone make a boot for the front driveshaft cv joint?
Mine hass ripped...must have disturbed the dirt holding it together when i did tranny swap...local yards have the whole drive shaft but i would rather do the boot if possible
pic...this may help.
http://i878.photobucket.com/albums/a...6509360632.jpg
notice the lube trail on the underside of the floor boards.
Thanks guys
Blazer_LT May 8, 2012 06:29 PM
is this what you're lookin for wart?
Amazon.com: Dorman 932-102 na Driveshaft CV Joint Kit: Automotive
it might be worth junkyardin
warthogdriver May 8, 2012 06:35 PM
Yeah...i started finding kits like that just a little while ago....i started calling yards after that.
Used shafts are 50 or so around here....i was wondering if i could do boot only...guess not
Thanks for the help though.
Blazer_LT May 8, 2012 07:56 PM
sorry that you gotta do the whole thing makes no sense at all. but glad you have a cheaper alternative
warthogdriver May 8, 2012 08:05 PM
Yeah...luckily yards by me have them...new shafts are 200-300 around local parts stores.
i just hope the boot failed because of age and not lift related issues.
Blazer_LT May 8, 2012 08:19 PM
well how long have you had you lift done as she sits right now
warthogdriver May 8, 2012 08:31 PM
the lift has been on for year and half....i did just have the whole drive line tore down for the tranny swap....so i am thinking i damaged it while monkeying with everything else.
the boot split right at the crimp on the shaft....if it were angle related i think it would have failed differently...it all still spins very well. so i am thinking it was my careless handling of the shaft.
i will know more when i swap it out this weekend.
Blazer_LT May 8, 2012 09:35 PM
you mighta snagged it when you were workin around it or something in that idea.
tripovermyego May 8, 2012 09:40 PM
Are you serious? $200! I checked with ORiellys and they wanted $69 a piece for brand new ones with no core charge and $59 for remans a piece with a $100 core charge each.
warthogdriver May 9, 2012 05:39 AM
^^^^ your thinking cv shaft going from front diff to the wheels.
i damaged the front drive shaft going from the transfercase to the front diff.
edit....ok here is my junkyard find, and it was 40.00 to boot.
http://i878.photobucket.com/albums/a...6570772605.jpg
http://i878.photobucket.com/albums/a...6570752853.jpg
thats the best part...it looks like new...even the u-joint looked new (minus the duct tape on the caps).
cant beat that!
here is the failed old boot
http://i878.photobucket.com/albums/a...6578851522.jpg
under closer inspection it was toast...the whole boot was just about to give way at the collar...rest in peace...you did your job well boot.
230k + miles...good job gm.
(taps playing in background)
