Front Driveshaft
Looking to replace my Front Driveshaft and/or put a conversion kit on the transfer case end. If you aren't familiar, there is a CV joint on the transfer case end of the front drive shaft. I put a 6" suspension lift on last year and as far as I can tell the new, steeper angle caused the boot to rip. I am told that there is a conversion kit that replaces the CV joint with a regular U-joint and then I can get a custom shaft fabricated at my local driveshaft repair place. Has anyone had any problems like this and do you have any suggestions on how to fix it?
Thanks up front for the help
Thanks for the welcome and the reply Chevy Lover.
Here is the info:
Make: Chevy
Year: 2002
Model: ZR2 S-10 Blazer
Other: I put a 6" Superlift on it.
I'm working on some pictures of the problem.
Any other info that might help?
Here is the info:
Make: Chevy
Year: 2002
So, I still haven't figured out how to fix my front drive shaft problem. Ran out of money and time over the holidays......
2002, ZR2
6" suspension lift
I looked into a conversion kit to put a standard type driveshaft on but, there isn't one available for the 2002, ZR2 Transfer case (GM-236). I then looked into just fixing the problem temporarily but the shop I talked to said the parts are on back order and that would just fix it for a little while. With the 6" lift kit the angle is too steep for the driveshaft which is a poor design to begin with. If I replace the transfer case I can have a custom shaft fabricated but that seems to be way too expensive. There has to be a better way. Any advice is appreciated.
Josh
2002, ZR2
6" suspension lift
Josh
Not a problem! That's what we're here for.
A clocking ring gets installed between the transmission and the TC. I'm not sure if one is available for your application, but I would definitely contact Superlift's customer support and ask them about the issues you are having after installing their lift.
I will definitely call Superlift and run it by them. I checked out their forums and noticed a couple of ZR2's on there that had the same lift. I'm wondering if this happened to them or if it was just a one time thng with mine. I may just be able to have that CV joint re-built. I found a place that does that but, they said the parts are on backorder and have been for a while.
Thanks again....
Thanks again....
Well when the parts installed have a limited functionality then some people get frustrated. And since the "CV" joint is actually two universal joints in a single housing designed for them there is a limited amount of height that can be applied to that before it becomes a failure point...
