Front End
Old Feb 28, 2011 | 09:10 PM
benthm7's Avatar
benthm7 is on a distinguished road
Default Front End
I own a 98 Chevy Blazer 4 WD LS. I hear a popping or click noise when turning in reverse and stopping at the floor board, what cause be the problem.
Old Feb 28, 2011 | 09:49 PM
Possibly ball joints, control arm bushings, sway bar end links... If it is only when you have the wheel cranked all the way in a particular direction, it could be a potential problem with the CV joints.
Old Feb 28, 2011 | 10:27 PM
benthm7's Avatar
Default Front End
Upper and Lower Ball joint, control Brushing, sway bar links brushing and tie rod ends has been change. The cv boots is in good shape
Old Feb 28, 2011 | 10:33 PM
Anything else been changed that you neglected to mention???
The boots being in 'good shape' really doesn't tell you if the CV joint is good.
Is the noise related to ground speed? Does it occur only when at the extremes of steering? Can you provide any more details to narrow it down?
Old Feb 28, 2011 | 10:47 PM
benthm7's Avatar
The speed for parking is less than 5 m/hr may be a hard left or right. When stopping, the speed is about 30 - 35 m/hr and I can feel the popping noise below the floor board on the driver side this will be the same for parking.
Old Mar 1, 2011 | 02:29 PM
If it feels like it is coming from underneath you, you may want to check out the cross member at the rear of the torsion bars. Also, have you checked your motor & transmission mounts?
Old Mar 11, 2011 | 05:10 PM
benthm7's Avatar
Default Popping Noise Pitman Arm
1998 Blazer LS 4 WD has popping noise coming from the new pitman arm, and the boot is damage. What could have cause this problem. Help please!!!
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
88s10Blazer
Jan 29, 2010 06:31 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
