Front end shimmy
Old Jul 22, 2018 | 03:52 PM
Tyson hebb's Avatar
Tyson hebb is on a distinguished road
Default Front end shimmy
Ok so I just replaced the upper and lower ball joints on the passenger side as well as upper a arm and upper and lower balljoint on driver side. At about 60-65 mph it has a shimmy but only at tht speed. Any ideas as to why?
Old Jul 22, 2018 | 04:06 PM
chevyriders's Avatar
Hard to say for sure, but I would check sway bar links and bushings. They can cause a shimmy at highway speed that wouldn't be evident around town.
It's also possible it could be a steering related issue, but I would suspect you would notice that around town as well.
Did you get an alignment after replacing the a arm?
Old Jul 22, 2018 | 10:35 PM
Alignment and tire balance are the first things that come to my mind.
Old Aug 1, 2018 | 07:52 PM
Radar696's Avatar
Radar696 is on a distinguished road
You didn't say anything about your vehicle.
If this is 4-wheel drive, then did you also check your u-joints in the front axle?
You would think if one was going bad it would show all of the time but it could be a joint that is starting to dry out and catching at speed.
porkfriedrice
Sep 30, 2014 02:40 PM
TommySkillz
Sep 17, 2010 09:49 PM
breakyadown89
Jul 27, 2009 11:08 AM
Devin
Apr 19, 2007 08:12 PM
