Front End - What's left to fix?
Old Apr 21, 2007 | 10:13 AM
Ian McBride's Avatar
Ian McBride is an unknown quantity at this point
Default Front End - What's left to fix?
Good morning everyone. I'm pretty new to this forum and have found a lot of what I've read interesting. I have a problem I hope someone can help me with. I have a 4x4 2001 S-10 Blazer.
I've had a lot of front end problems and in recent weeks have had the following replaced -
R/F Bearing
2 front tires
Then yesterday...(at a Chevy dealer)
Upper and lower ball joints
Right and left inner tierods
Left outer tierod
Idler arm
Then they did an alignment
So after all that I took it on the highway last night and it still felt like at any moment it was going to pull off to the side of the road. And it vibrates at pretty much any speed.
Does anybody have any ideas as to what it could be. Maybe the l/f bearing? Or maybe they did a horrible job on the alignment? As you might tell I am pretty mechanically ignorant.
Thanks
Ian
Old Apr 26, 2007 | 11:19 AM
blazinloud's Avatar
Default RE: Front End - What's left to fix?
these trucks seem to have lots of front end problems......im sure someone here can help you out.......
Old Apr 26, 2007 | 07:44 PM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Wow, you must have spent a fortune getting that stuff replaced. Someone else on here will help you out. Good luck!
Old Jun 9, 2007 | 12:20 PM
scotty_btm's Avatar
scotty_btm is an unknown quantity at this point
well, that's a pretty good list..what about the Pitman Arms?
Old Jun 9, 2007 | 02:55 PM
wulfe13's Avatar
wulfe13 is an unknown quantity at this point
The vibration is probably from the tires not being balanced properly, alignments don't cause vibration. If it pulls left or right it's most likely a poor alignment or they just did a "toe and go" and didn't set the Caster or Camber, but sometimes a bad tire will cause a pull.... even new tires...
If they gave youa copy of the alignment specs and you can scan them to your computer and post it here, I can tell you whether or not its causing the pull.
Old Jun 10, 2007 | 03:37 PM
Thanks, I'll take it to a front end place to see if it needs a balancing, or even an alignment.
They didn't give me any kind of printout for the alignment, just the bill.
r_marczak_83
17
Mar 9, 2013 10:33 AM
cahlersmeyer
Nov 8, 2011 04:12 PM
blazernoobie
Jul 13, 2009 08:58 PM
stark05
Feb 21, 2009 01:24 PM
Dodge Guy
Oct 25, 2006 08:48 AM
